Yes, it's "B". I DO add a liitle more. After drivign a while and then re-setting this code, although, should this code still activate?
NISTECH wrote:When you get gas do you;a) stop adding fuel when the pump clicks offb) add a little more gas to even out the dollar amount
If you choose be you may have gotten fuel in the fuel cut valve lines. The purpose of the fuel cut valve is to stop the gas pump and prevent liquid fuel from entering the evap system. If the valve gets inundated with liquid fuel it will throw this code.
