99 Pathfinder Cargo Window Stuck
bradleysf
Car: 1999 Nissan Pathfinder
The cargo window on my 99 Pathy is stuck. The cargo door opens fine, just not the window. Even when I try to turn the key on the outside of the cargo door to unlatch the windown, the key won't even turn. It will turn counter-clockwise to unlock the cargo door, but it won't turn clockwise to unlock the window.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Remove the rear door's trim and see if the lock rod is jammed up on something.
Welcome to NICO!
Leo1998
Car: 1998 Nissan Pathfinder
Towncivilian wrote:Remove the rear door's trim and see if the lock rod is jammed up on something.
Welcome to NICO!
http://www.nicoclub.com/FSM/Pathfinder/ ... der/bt.pdf
Did you try some WD40?
