99 Pathfinder Auto Transmission Issues...Please Help me Diagnose...
OE812
Car: 02 Frontier kingcab 2.4L
This is the first time I've had a driveability issue with my Pathfinder. Mileage is 78,000 and I changed the transmission fluid and filter about 10,000 miles ago. The pan at that time was clean with no metal fragments. Used 8-9 quarts of Nissan D transmission fluid. Anyway, I am getting 3 potential transmission issues and need to know where to start.
The first issue is when I shift from reverse to drive, there is a 1 to 2 second pause before it engages in drive so I can accelerate. It doesn't matter if the operating temp is cold or hot.
The second issue is as I am coasting >50mph and slow to 30-35mph and try to accelerate, the transmission doesn't downshift to 3rd or 2nd. But when I floor it, it abuptly downshifts to 1st and nearly red-lines until I back off of it.
Another transmission issue it is exhibiting is a whirring noise while coasting between 20 and 25mph with the overdrive on. When traveling at this speed and coasting and switching overdrive off, the whirring noise goes away. Switch it on at this speed, the noise is back. What could be causing this noise?
Fluid looks and smells new. The level is fine.
Where do I start?
Any help would be appreciated.
