99 Maxima - Comments on CV Boot Changeout - What did we do wrong?
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
My buddies and I worked on the CV axle
My friend just wanted to change out the boots andnot the entire axle.
The axle tapped out ok and the seals to the transmission did nottear and most everything was ok until.....
We tried to get the boot over the ball cage. It was so tightthe three of us had 5 needle nose plier on it in a vice. We finallygot band around it and it went in fine. I just can't believe it wasthat much trouble to get it on.
We were like three greased up monkeys in a..........
maxhopper
Car: 02 Maxima SE 6spd
Soaking the boot in hot water might have helped.
I just replaced the whole axle when my boots ripped.
NutriaforBreakfast
We didnt take the balls out of the cage
Just cleaned out the old grease and looked for pittingetc. Save a lot of $!
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
NutriaforBreakfast wrote:Save a lot of $!
Not really. How much did the boot cost you? $15-$20?
And how much time did it take to replace it? 2?...3? hours?
I got a rebuilt axle for $50 after getting my $5 core back. It took my father-in-law and me about an hour and a half to change it out and that was with my internet intermission to find pictures.
So for $30 you could have saved an hour or two and had a "new" axle with a one year warranty.
NutriaforBreakfast
You are correct.
It wasnt my car but a friend's who was broke
I tried to tell him what u said but he had nutria fur in hisears and wouldnt listen
NutriaforBreakfast
Who rebuilds these CV joints in Dallas Texas?Or if I need one do I have to go to Auto Zone or someother auto supply?
What type of place rebuilt yours? Was it a long wait?
maxhopper
You can get remanufactured axles from pep boys or autozone for about $50-65 with a lifetime warranty.
Sentientbydesign
96 I30 - Sold
I got mine from a local independent parts place. They had the part for me the same day.
If I remember correctly, it was a Cardone part.
NutriaforBreakfast
Well I found out my instinct to NOT resuse the old CVjoint was correct. Apparently a clip on the shaft was notput on right.
He was turning to get a hamburger and the half shaftpopped out of his transmission. I toasted somethinginside the tranmission.
The moral of the story is: DONT REUSE OLD PARTS unlessu know what your doing
Sentientbydesign
96 I30 - Sold
That worries me now. I don't remember a clip on my cv axle.
Was it on the transmission side or at the joint?
Is there a difference between the 96 and 99 for that area?
NutriaforBreakfast
Not sure which side but can find out later
There appears to be a snap ring on the end of the shaft
I told them both not to reuse those joints
I guess since he was in a turn the transmission got its gearsin a bind. Anyway the transmission wont turn and just makesa whole bunch of noise.
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
You have to tap the axle back in the trans until it locks (snap ring) or else it will pop out. you might damaged the output shaft/planetary gear on the differential.
maxhopper
There is a "C" clip on the end of each axle that goes into the transmission.
I'm not sure if you're referring to some clip in the actual CV joint itself.
NutriaforBreakfast
It was the C clamp you are mentioning
I will bet that thing got bent by hammering or movingaround
xerexabante
that is called a snap ring or c clip to you
Sentientbydesign
96 I30 - Sold
Whew! Ok, I was worried that there was some sort of clip at the edge of the transmission where the seal is.
Is it just me, or did it seem too easy to take out and put in the CV axle?
I expected a big to do with special tools and bolts holding the thing in, but just a large flat head popped the sucker out.
NutriaforBreakfast
Yeah they were easy to get out
Not like a regular u joint
NutriaforBreakfast
I heard now the transmission is NOT toast.
My friends went back over to the hamburger parking lotand jacked up the car. They put in two brand new CVjoints and the car runs fine.
Moral is still the same: Dont run used parts
