Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Sun Apr 22, 2007 5:00 pm
Sounds like you need to bleed the brakes. First, did you open the bleeder valve when you backed out the piston? If not, you may have damaged the piston.2nd You need to get a friend, jack up and secure the car on jack stands, then start the car. Have your friend step on the brake and hold it. Then you open the bleeder valve. Close the bleeder valve, then your friend lets up on the brake pedal. Have him pump the brakes, then press and hold to floor, while you open valve... repeat until you get clean fluid. Check the reservoir often, to make sure that it stays full. Also, start with the rear passengers side, then rear drivers, then front passengers, then front drivers side. Working from the farthest wheel from the master cylinder, to the nearest.
