99 infiniti q45t headlamp
ritzy99
Car: 1999 infiniti q45t
my passenger side headlamp doesn't work. neither the high beam or the xenon beam. the parking light does work. a new headlamp assembly is like 1200. can't find a used one anywhere. i actually am not even sure i need a whole new assembly does anyone know about this? can i just replace the bulbs or do i have to replace the whole headlamp assembly
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
You can replace just bulbs. Head to a local parts store to grab the bulb. Mind if the new one (even if same color temperature) will probably look different as they age, so you may want to replace both.
I've never replaced bulbs on my car - I believe the highs and lows are separate bulbs, if that's the case I'd suspect a different issue as it's suspicious both would go out at the same time. Look with your eyes - if it's one bulb, replace it. If it's 2 bulbs, then you need to look at a possible harness issue (my best guess).
Someone else will chime in regarding 1 or 2 bulbs...........now......
Q451990
I would swap your bulbs left to right to see if the bulbs are actually the problem. Having a failed high beam is very unusual. Review your FSM (Factory service manual) available in our library at http://www.nicoclub.com/FSM/ to see if there are relays or fuses involved that may help. As a last resort you can look for a replacement used assembly at http://www.car-part.com
Welcome to NICO!
Heath
