99 I30 Inner Tie Rod replacement
rlguarig
Car: 1999 Infiniti I30
Hey Guys,
I've got it down to the inner tie rod end showing - outer end is removed and dust boot is also removed. I can't seem to get the little lock-nut to let loose without really tearing it up. Though I have new ones, so I guess I shouldn't worry about that. I think I need a special tool to remove the inner tie rod ( part number 96558-0VGA at Harbor Freight). I'm guessing that I finish tearing up that lock-nut, use the tool to unscrew the old tie rod end and PRESTO! It's off. To install the new one, do I just slide the new lock nut on, then screw on the tie rod, then somehow snap the lock nut onto the tie rod end?
Your help is much appreciated.
RalphPhoenix, AZ
