99 Altima Rough Idle
General discussion area for the L30-chassis Altima
leftoverture
Hello! I am working on a 99 Altima with 182000 miles on it. It is not my car so I know virtually nothing about the car's history. The engine light is on and it idles rough. I am getting codes P0400 (EGR flow malfunction), P0325 (knock sensor circuit malfunction), and P0171 (system too lean). This car belongs to my son's fiance and she doesn't have much money so can't really afford to throw parts at it, so hoping that someone might have some input as to where to start with the diagnosis and any tips for diagnosing this. Thanks!
sky5031
Car: ???? Nissan 200SX
???? Nissan 240SX
???? Nissan 300ZX
???? Nissan Altima
???? Nissan Frontier
99 altima p0400 egr malfunction: this usually means its stuck or full of carbon, alot of this carbon from the fuel grade used more so in winter because of the ethanol (alcohol) sewems to delvelope on the valve system around the erg valve. clean /replace. the other two
code will more than likely go away because the recir system will restore air to return hot gas to engine balance. sky5031
ItzNick Trash
Car: 1998 Nissan Altima GLE 2.4L 16v DOHC
Also the knock sensor is not essential and it's extremely hard to get to. I managed to get mine off but there's was no way I could put it back in the way I got it off so I just disconnected the electrical connector and the code went away.
Return to “2nd Generation Altima Sedan (1998-2001)”
