99 Altima GLE automatic to manual
General discussion area for the L30-chassis Altima
KoTT
Car: 1999 Altima KA24DE
how hard would the conversion be? I understand you gotta put in the new gear box, clutch and flywheel. how hard would it be to do, worth it or not in your opinion, or any general tips anyone?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Shouldn't be too bad if you have all the parts needed. It's all labor at that point and Nissan gives you most of the cut out points already. So armed with a dremel and your standard tools you should be able to pull this off with a minimal amount of swearing.
Jybfan04
Car: 98 Nissan Altima
91 Nissan 240sx
There are writeups available on nissanclub.com and supernissans.net...
Check over there...
Return to “2nd Generation Altima Sedan (1998-2001)”
