99 Altima 248/240 Cam Swap? Intake cam Adjust?
General discussion area for the L30-chassis Altima
PAAG86
Car: 99 Altima
Hey guys im new to the forum, I recently inherited a 99 altima. It had a blown motor and the family had basically thrown it away so i threw a fresh motor in it and some other basics and got the car back on the road. Ive decided to start doing some minor mods to start playing around with it a bit and once i get used to these cars and type of motor and tuning...get into bigger mods and make it a solid street car.....my goal for NOW is to make it a fun car to drive around the city 40-60mph with power throughout the band but focusing on mid and top.....so 3.5k to 7k rpm?
I have been doing a lot of reading between the forums on cam swap options between the KA motors and I learned that for my particular 2nd gen altima....i could use ANY cam from 97 and down altima, s13 and s14 Ka24de motors as my altima intake cam but could only use 98 and up ALTIMA exhaust cam as my exhaust cam because of the distributor. That being said...I was thinking of using a 240 exhaust cam from a 00 or 01 Altima and a 248 cam from either a s13 s14 or altima prior 98 as my intake cam to make a 248/240 combination....
Now I have read and read through a lot of threads for the last three days and only found ONE person with an altima who has done any cam swapping at all....most swaps were on s13 and s14 engines...but the guy has done the 248/240 combination on his 00 altima. but his post was very brief and there wasnt much information about anything. However I saw plenty of posts of the 248/232 combo and the 248/248 combo and the 240/232 combination on s13 and s14 motors but as I understand it....since I have a 98 and up ALTIMA ka24de these combinations arent possible because of limitations of the exhaust cam in my 99 altima.
Im wondering if anyone has a 98 and up Altima KA who has done cam swapping and has a 248/240 combination or different with any good results and what are they? Is there any other combos that one could recommend? ALSO i read a post about a ADJ cam sprocket DIY and was wondering IF I did the 248/240 combo if advancing or retarding the intake cam would get more performance out of this combo? And last...which 248 cam from 97 and prior KAs should I use as my intake cam? They are closely similar as far as lobe height but differ in open and closing degrees and wondered how lenghts in valve over lap would affect performance and at the same time if by making the Adj cam sproket i could make the best of things? here are the specs for Intake Exhaust Cams I found on a thread:
1) ’91-’93 240SX (S13) - Note: '94 exh specs are slightly different
intake cam = 240 deg duration with a 1.6699”-1.6774” lobe height
(intake opens 1 deg after TDC & closes 61 deg after BDC)
exhaust cam = 248 deg duration with a 1.6699”-1.6931” lobe height
(exhaust opens 64 deg before BDC & closes 4 deg after TDC)
2) '94 240SX (S13)
(exhaust opens 60 deg before BDC & closes 8 deg after TDC)
3) ’95-’98 240SX (S14)
intake cam = 232 deg duration with a 1.6699”-1.6774” lobe height
(intake opens 1 deg after TDC & closes 53 deg after BDC)
exhaust cam = 232 deg duration with a 1.6699”-1.6774” lobe height
(exhaust opens 48 deg before BDC & closes 4 deg after TDC)
4) ’93-’95 Altima
5) ’96 Altima
exhaust cam = 248 deg duration with a 1.6856”-1.6931” lobe height
(Note: Ca exh cam has 232 deg duration with a 1.6699”-1.6774” lobe height)
(Note: Ca exhaust opens 48 deg before BDC & closes 4 deg after TDC)
6) ’97 Altima
7) ’98–’99 Altima
intake cam = 232 deg duration with a 1.6734”-1.6809” lobe height
exhaust cam = 216 deg duration with a 1.6104”-1.6179” lobe height
(exhaust opens 32 deg before BDC & closes 4 deg after TDC)
’00-’01 Altima
intake cam = 224 deg duration with a 1.6551”-1.6626” lobe height
(intake opens 1 deg after TDC & closes 45 deg after BDC)
exhaust cam = 240 deg duration with a 1.6551”-1.6626” lobe height
(exhaust opens 53 deg before BDC & closes 7 deg after TDC)
9) ’98-’00 Frontier
intake cam = 232 deg duration with a 1.673”-1.681” lobe height
exhaust cam = 216 deg duration with a 1.610”-1.618” lobe height
10) ’01-’04 Frontier
intake cam = 224 deg duration with a 1.644”-1.651” lobe height
exhaust cam = 224 deg duration with a 1.646”-1.654” lobe height
(exhaust opens 37 deg before BDC & closes 7 deg after TDC)
And guys i understand i could just buy aftermarket cams and be done with it...but im just playing aroound with stock cam options for now so telling me to not waste my time and go get an aftermarket cam isnt really any help lol.....thank you in advance ad SORRY FOR THE LONG READ AS MY FIRST POST....thanks!
frapjap
'07 Subaru Legacy
I know you solved the problem already, but I want to merge all of your threads together. You have some awesome research and info compiled!
PAAG86
Car: 99 Altima
frapjap wrote:I know you solved the problem already, but I want to merge all of your threads together. You have some awesome research and info compiled!
Thanks man! merge what you need to man...whatever helps the next guy! And yes I got the cams installed and running and happy with them, Im still wondering whether making an adjustable sprocket for intake and or exhaust cam will allow me to squeeze a little more power from this combo? do you have any info on that? Thanks!
frapjap
'07 Subaru Legacy
Adjustable sprockets make it easier to do some trial and error to find some more power, but I wouldn't go adjusting the timing too much more without a wideband 02 sensor to tell you if you're running too lean.
Return to “2nd Generation Altima Sedan (1998-2001)”
