99.5 Fog re-wire question
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
Last year, I did the fog light mod. I'm using the factory relays, and I have the switch power for the fogs running to the switch power to the A/C.
My driver's side fog light bulb died, so I replaced that. Recently, my passenger side fog light also stopped working, so I got a bulb and proceeded to replace it. Not only was the bulb that was there fine, but I noticed the plastic surrounding the plug for the ground wire was melted (driver's side was perfectly fine). I soldered on a new wire (I'll do it right and get a blade connector soon, lol) and it works fine.
My question is, is using the switch power for the A/C a bad idea? Did this melt the plug, or was it possibly something else? My opinion is that the switch power for a given relay isn't going to be more than the next relay, especially one that's the same exact part.
Note: I had no problems for a very long time.
KoukiS14
It's prolly fine -- I didn't have any problems this morning. I just have to re-do my crappy soldering job.
fueler
Car: 2 Nissan's
2 BMW's
I use the same A/C switch, longer than you for sure, withno problems
KoukiS14
Sweeeeet. . it's probably fine. May have melted from something else, possibly heat from the light or maybe it got some water in there and shorted, I have no idea. It was a super easy fix regardless, and damage was very very minimal.
Also, I drove around with 'em on and then popped it open and took a whiff -- no burning electrical stuff.
Thanks G!
