98' TCM location ?
mikemann01
Car: 98 Infiniti Q45
can anyone tell me the location of tcm in a 98' ? , looked through the fsm - might have missed it - search turned up nothing for a 98'
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Looks like it in the same place as it is in my car....the driver's side kick panel.
Check out page 10:
http://www.nicoclub.com/FSM/Q45/1998_Q4 ... Q45/at.pdf
mikemann01
Thanks Lino thats where it is , Do you know if the numbers have to be the same to replace it just like the ecm ?
lino
Without having your VIN I can't verify which part number is for your car, but I can provide you with all the part numbers that apply to the FGY33 model series:
31036-6P100
Prod.M/Y:0796-0397
that part number supersedes to -->31036-6P101
31036-6P101
Prod.M/Y:0397-0198
31036-6P600
Prod.M/Y:0798-1199
Prod.M/Y:0198-0798
that part number supersedes to -->31036-6P601
31036-6P601
Prod.M/Y:1199-
mikemann01
Here is my vin if it will narrow it down - jnkby31a0wm502422 , Thanks Lino
lino
31036-6P600 is the correct one for your car and that part number supersedes to 31036-6P601 which means that will work too.
More info about your car:
VIN - Code: JNKBY31A0WM-502422
Model: BPFALGAY33EUA----A
Model Series: FGY33
Prod.M/Y: 0498
Color:# CRO (BEIGE)
Int.Color: C (COCOA)
Body: S (SEDAN)
Engine: VH41DE (VH41DE TYPE ENGINE)
Emission: FED (FEDERAL)
Grade: L (L GRADE)
Trans: AT (AUTOMATIC TRANSMISSION)
Breakdown of Model: BPFALGAY33EUA----A
First 13 characters (BPFALGAY33EUA):
B = BODY (B:SEDAN)
PF = ENGINE (PF:VH41DE)
A = AXLE (A:2 WHEEL DRIVE , B:HICAS)
L = HANDLE (L:LEFT HABD DRIVE)
G = GRADE (G:NO GRADE)
A = TRANSMISSION (A:AUTOMATIC)
Y33 = CAR MODEL
E = INTAKE (E:EGI)
U = DESTINATION (U:FEDERAL , V:CALIFORNIA)
A = SEATING CAPACITY (A:STANDARD)
Characters 14-18 (----A) are option list:
- = STANDARD
- = STANDARD
- = STANDARD
- = STANDARD
A = F/SIDE AIR BAG
mikemann01
Thanks for the breakdown Lino and the tcm numbers that help alot.
lino
My pleasure :dblthumb:
