Ridge Racer »
https://forums.nicoclub.com/ridge-racer-u24795.html
Sun Jun 19, 2005 6:31 am
OK - so assuming I was going to replace the fuel injector, is that a part that I should definitely get from Nissan - rather than from an auto parts store?
Also - it sounded like you don't think the possibly bad injector would cause the problem I'm having. (hesitation/stumble) Is that what you were saying? Should I test the fuel pump or something?
Since I had already tried most of the things that made sense to try - I took the EGR stuff (EGR valve, BPT valve and EGR pipe) off yesterday and cleaned it all out w/ carb. cleaner. The pipe really wasn't very dirty. Slapped it all back on with a new EGR gasket. Problem still there. Not that I expected it to go away, mind you - but I thought I'd give it a shot.
I don't know if this will help narrow anything down - but it seems to happen mostly when the car is in overdrive (4th?). I will give it a little gas and the rpm's on the tach. will drop suddenly about 200-300. Then with a little more gas, the rpm's jump up about 400-500.
I looked at the timing marks again, but I couldn't see one mark that was a different color than the others. They all looked white to me. I am wondering if having the timing set incorrectly would even cause this kind of a problem. Seems like I would have a problem across the rpm range if the timing was set wrong.
Well man - I know I'm getting pretty damned tired of working on this car, so I'd imagine you are getting tired of reading these posts! I'm one of those people who will try to solve a problem until it's solved, completely ignoring things like my wife, work, eating, bathing, etc. If you have any suggestions or ideas at this point - please let me know. If you have reached the end of your willingness to help, or are out of ideas - I can completely understand. I am getting to that point myself!
Thanks for all your help!
