98 S14 Compression Test numbers anyone?
Acuratechva
Car: Black Kouki
anyone know what they are... i was about to call the dealer buthtey're closedtahnks in advance
k6kicker
Car: 90 300zx(tt) 95 240sx
175~180?
98s14inaz
Car: 2010 Nissan Titan Quad Cab
You biggest concern should be whether or not they are close to the same number. If they are drastically different from each other you may have a problem.
KFL
Car: S14
Standard 179psi Minimum 151psiDifference between cylinders 14psi
BadMojo
Car: 2007 Mazdaspeed 3
Just so you know, the procedure is:
1) Get the car up to operating temperature and then shut it down.
2) Remove the gas cap and then pull the fuse for the fuel pump. Start the car and run it until it dies. Crank it once or twice more for good measure. You've now released fuel pressure.
3) Pull all plugs and wires. Make sure you don't manage to zap yourself when doing the test.
3) Carefully thread the tester in to the spark plug wells, hold the gas pedal all the way down and crank the car 4 or 5 times. Repeat for each cylinder. I did the test twice total just to make sure I was getting consistent numbers. Make sure you're at WOT.
4) The compression specs are mentioned above. If you've got one or more low cylinders, dump a cap full of oil down the spark plug well and wait a minute or two and then retest. If your numbers jump up significantly, you may have damaged rings. If you've got two adjacent cylinders that are low, it may be the head gasket.
5) If you've got poor compression on one of more cylinders, I'd have someone do a leakdown test to pinpoint the problem.
Anyone else please feel free to correct me if I missed something here. It's pretty damn late and I'm tired.
tryiian
Car: 95 blue emerald s14 KADE traded for 1992 black hatch base
pretty good bump here, does anybody know where the fuse is on 0bd1 s14s?chiltons says it`s under the dead pedal, it`s not, at least not in my car.
