98 rb25det s2 wiring help
zman07
Car: 1987 nissan 300zx, soon to be rb25det powered
ok, i know many people have tried looking for this stuff before, and i know im not the only one that has asked this, but if someone nice enough to help me out id appreciate it.
<a href="http://s129.photobucket.com/albums/p225 ... ure736.jpg" target="_blank">a>
<a href="http://s129.photobucket.com/albums/p225 ... ure737.jpg" target="_blank">a>
does anyone have the wiring shematic for this plug. its hard trying to find a clear one that is easy to read.
<a href="http://s129.photobucket.com/albums/p225 ... ure739.jpg" target="_blank">a>
<a href="http://s129.photobucket.com/albums/p225 ... ure740.jpg" target="_blank">a>
does anyone know where the cut wires go to . they never had clips on them or anything, and its driving me nuts looking at them.
<a href="http://s129.photobucket.com/albums/p225 ... ure738.jpg" target="_blank">a>
and does anyone have an extra clip. it goes to an 98 rb25det s2
if anyone could help i would appreciate it
tight240
Plug 1. That looks like the plug that you use to actually splice the harness into the car. Dont know where you can get a good schematic, you going to have to use the R33 FSM wire schematic and find somebody thats good with wiring.
2. By where the wires are located, and looking at those 2 thick white wires, look like they go to the plug that connects the lower harness to the upper harness. Those 2 thick wires look like they go to the knock sensor signal wire (shielded) and there should be 2 smaller wires that should be the same color that connects to the knock sensors as well, they should be black. The white wire and black wire are joined together into 1 shielded wire that goes to each knock sensor plug, so that should be 4 of the wires. 2 other wires goes to the Air Regulator plug, that sits underneath the intake plenum, its usually a blue plug. If its the connector im thinking of then that should knock down 6 wires out of that bundle. it look like the wires that goes to the plug im thinking of.
3. Offcourse that plug goes to your ECU, i believe a Z32 or J30 main ecu plug will work, you just have to re-pin the whole thing correctly, i know alot of poeple are using the 300zx ecu's for NISTUNE, so that connector should work, you have to go to the junkyard.
Hope that helped some.
zman07
thanks man i appreciate it
eh?
I have some good Diagrams here:http://www.rbforums.org/4.html
zman07
thanks (eh?) awesome name by the way
tight240
you welcome, im in the process of wiring my rb25 as well, when everything is done i will post pics, and video of the process. Did a 20-25 swap using as much as my 20 parts as possible. (eh?) i see the forums is comming all together, good work. We need a RB community since Racebread is not up.
zman07
thanks u guys
eh?
Did you get it all worked out?
zman07
the info u guys gave me really help me understand whati was doing, but im wondering if i should let carl modify my harness to fit my z31
tight240
I hope you post some picks up of the car when its done. I was thinking about rebuilding my rb20 and throwing it into a Z.
eh?
Have you tried Hybridz.com for Z31 wiring help? There's someone over there by the name of Racinjitter who has an RB25 in a Z31, maybe he can help.
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
I have a question too... what are these wires for? It is a red connector with two wires (orange and black on the harness side)
what are these two wires for? What is this? and shall I do with it, putting my rb25det into s14?
PhenomR33
Car: 1998 Nissan Skyline GTS
Romeo_rus wrote:I have a question too... what are these wires for? It is a red connector with two wires (orange and black on the harness side)
Those 2 wires are near the windshield wiper motor plug, you should transfer the power wires out of it if you need a source for teeing into the car.
the extra plug isnt needed, the larger of the 2 is the dash harness ( start signal, fuel, MIL / CEL, IGN / TACH, and water temp that will need to be cut into your 240sx dash harness
Hope that helps
zman07
these wire harnesses arent as easy as they look. there should deff be one page describing exactly what eac h clip goes to and what no. sometimes the wiring diagrams just arent enough
Romeo_rus
What about the red connector? anybody knows?
Carryl
the one circled in red i believe.. is the abs stuff
BigC_1988
Car: Nissan Skyline R32
Can anyone send me the pinout for that plug (the big incabin one) and any info you may have that could be usefull. I'm in the middel of swapping a rb25 S2 in my r32. I'm stuck at the harness part.
xDRFTurR1D3x
Car: 98 kouki- S2 RB25- f*ck you fed ex and mother nature!
93 s13.4 kouki/coupe- bottle fed modded KA- VH45 almost ready!
i used the wiring diagram on rbforums.org for my f3 plug as well. just posted a thread to confirm my repinning was correct. OP should check it out to compare? would love your feedback on yours as well
BigC_1988
Do you have the pinout for the plug near the power steering resivour (for 12V IGN ect)?
BigC_1988
Can anyone axplain how the power feed works on the RB25 series 2? I finished connecting all the wires to the dash (the 3 R32 plug are now on the RB25 harness). But I still can't figure out how the power goes...On the plug (8 pin) near the power steering I have 7 wires which are:1. Green/red = signal to A/C2. Yellow = ????3. Green/orange = Neutral switch4. Light blue = Power steering idle up5. Blue/red = wiper IGN6. (thick)Red = ????7. (thick)Red/blue = ????Hope someone could help.
BigC_1988
Hope that helps
I traced the smaller plug back and I believe they go to the coils....correct me if I'm wrong. If so how do the coils get power on the S2 engine?
Built2Slide
Car: 89' s13 coupe rb25
I am swapping a series 2 rb into my 89s13 i am also wondering where that plug goes. the small yellow wire traces up to the purple connector that goes to the air valve (i think) on the intake. And most of those seven wires go to the extra plug down by the ecu, besides g/o, g/r and l/b. I need some help as well with the power to the injectors and the s13 swap if anyone knows info for the series 2 swap. haven't been able to find much info on the series 2 into the s13, and definitely haven't found a good wiring diagram for the series 2.
trynam4size
Car: 240sx
Trying not to steal this thread, but I've done some searching as well (before I posted) And I did come across the link (:http://www.rbforums.org/pics/rb25s13.jpg [ cause I'm trying to go from a 89 auto to a rb25det man]) Could someone help explain to me why or what I'm suppose to do with the
1) Water temp2) Tach out?
Correct me if I'm wrong, but they're asking for the pin 1 on the KA harness, and yet its suppose to be Blue/Black, than magically turn into Yellow/Red?
Thanks in advance guys!Namco
