ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sat Aug 27, 2011 1:01 pm
If you clean the throttle body with carb cleaner, remove the conduit up to the metal throttle body, pick a rag under the threshold of the throttle body, use an old long handle tooth brush that is clean.
Engine off. Spray inside, open throttle to full and hold open, spray, then brush every surface including the throttle plate both sides. Spray agin, close throttle plate let sit for 5 minutes, come back re spray and look for more carbon especially where the throttle plates rests around the circumference.
Try opening and closing the throttle plate, do you feel sticking? You should not, but if you do re clean. When done the inside bore of the tunnel and the plate will be shiny and clean. The further down your intake throttle you can not brush clean but you can spray with cleaner let sit examine then put everything back and try to start the engine.
It will take a couple times to have enough fuel over power that chemical soup and carbon crap that would run down into the fire chambers. But when running be gentle with the throttle until your running on gasoline, then goose it. A little Seafoam now in the gas tank would help keep it clean, A LITTLE.
remove the rag and button her up, make sure the air conduit is tight and no leaks, change the air filter if not done in a while.
With everything buttoned up now liberally clean the outside right side of the throttle area with that cleaner but be stingy on using it. Let dry then spray a little WD40 onto the bearings and pins and spring, just a bit
The cleaner will remove grime, the WD40 will displace water and lubricate.
As to the IAC, use Carb cleaner, wrap the valve with a rag to hold the chemical nar the valve, let sit, respray, blow out with compressed air, make sure it is dry, re install. Check out the hoses for carbon, if any spray with cleaner until wet, test it, examine until all carbon is gone, reassemble.
The EGR is a bit easier to work your magic, at warm up, at idle, take a hammer and give it (EGR) a few light raps with the hammer, just enough to vibrate that round dish and if any carbon is in there it will be sucked into the motor, keep lightly hitting it, the idle may cough and fart if so the EGR is getting rid of crap, continue rapping that EGR until the idle returns to normal.
If the motor dies, open the throttle wide open engine off, then with 1/3 throttle open try starting, if it starts give it a few quick revs, the idle will come back to normal.
Get back to that EGR and hit it again, if idle stays the EGR is clean enough for idle control. Now maintain it.
The hitting will work sometime, and if you cannot clean the EGR that way you have no choice but to remove it, open it, clean it...or replace it. And if you are lax on servicing it time will cause you to buy another EGR.
The amount of PM is determined by time and distance and the amount of actual careful work that is done when doing the PM. Most guys that do actual work on their own vehicle do that job better than a professional, not because the pro is no good but the guy doing the work is doing something that he enjoys and it is his. As DIY many go further than what the pro would do. These PMs do make a difference and the work facing you is very dependent on the condition of the parts you are about to pull apart and clean.
Carbon is a tough material. It may not be removed with a single cleaning effort, how much is there and for how long will play a critical part in removing it. Be sure you do not reshape, chip, destroy the metal parts of the engine. You want to remove carbon build up. If your engine is carbon fouled using full strength Seafoam or any carb cleaner must be used with care and use a little at a time.
Carbon while being removed is an inactive substance with a very active fuel mixture. Removing carbon from an older vehicle must be done in a delicate no event manner by diluting Seafoam for example in a full tank of gas instead of sucking in a 1/2 bottle through a vacuum line. A 1/2 bottle with a full tank will remove the carbon build up over time as the tank empties and will not damage gaskets, seals or leave chunks of carbon particles around to block passages.
Be careful, be purposeful and take your time.
