boogar »
https://forums.nicoclub.com/boogar-u44423.html
Tue Aug 01, 2006 5:39 am
Mass air sensor
As they get hotter during driving, they will begin to fail.
Youll notice spitting , sputtering, and maybe some small muffeled back fires.
One major problem that can result from a bad MAS is the underside and exaust system starting on fire.
A bad MAS causes more fuel than is needed to be dumped into the maifold.
When this fuel doent get burned, and it pours thru the engine, choking it off.
If you keep pushing it, it will flood the exhaust sys with fuel and start a fire.
Be careful and good luck
