98 QX4 headlight turn signal blinker switch malfunction
claudiotosco
Car: 1998 qx4
I have a 98 qx4 and my multi light switch doesn't go back to off position(stays on) after activating it(making a right or left turn)....I already replaced the switch and I'm having the same issue.
Any ideas what the problem could be?
Thanks for any help.
frapjap
'07 Subaru Legacy
That is a weird one.
I'm not super clear on whats happening- can you help me out?
Are you saying that after you complete a turn, the turn signal stalk doesn't automatically pop back into the 'off' position?
or are you saying that the bulb indicator in the gauge cluster isn't going off?
If its the first one, there is usually a little cam in the steering column/wheel that pops it back into place.
If its the latter, there is a burnt out bulb somewhere.
I'm not intensely familiar with QX4's, but take a peek at the FSM to see if it might have some photos or steps for you to take.
http://www.nicoclub.com/archives/infini ... nuals.html
claudiotosco
Car: 1998 qx4
The first one. it doesn't pop back into place.
Thanks for the help.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
The cam that cancels the turn signals is probably broken.It is part of the switch base that surrounds the steering column.
claudiotosco
Car: 1998 qx4
Thanks sx moneypit. Could you please tell me what part exactly should I be replacing?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Nissan calls it a combination switch.
Ace2cool
