chaonis »
https://forums.nicoclub.com/chaonis-u45178.html
Tue Mar 17, 2009 8:27 pm
done.
Here is the procedures:1) remove the screw on top of the clearance lamp (FSM: BT-5, D3);2) pull the clearance lamp straight out. no side turning, just straight out. unplug the cable.3) remove the screw on the grill strip under the headlamp, push the clip next to the screw out of the hole, then slide the grill sideway out (FSM: BT-7, G7);4) pull out the radiator grill, there are five clips (CG101), two on each of the headlamp assemblies and one at the center. a noise plier will help. (FSM: BT-6, 4);5) remove the 4 nuts on the headlamp assembly, one on upper-left corner, behind the radiator reserve bottle, two on the right side, one under the bottom center of the lamp, deep inside.6) unplug the electric wire, turn and slide the headlamp assembly out. a clip might be in the way (BT-7, K), just use a flat head screw driver to push it down a little bit.
only tool needed is a 10mm socket.
by the way, I put the assembly in the oven at 280 degree for 10 mintues, no effort to pull apart the cover lens and the housing.
next project is to figure how to remove the bottom cushion and swap them.
