'98 QX4 Fan/AC jitters
jkill416
Hey everyone! Ok, so I've taken the red power off my battery hundred's of times. I have a sub in my car and have always done the installations myself and never had any problems. My 4 gauge connector recently broke and I got a new one and so I took off the positive end and installed the new one like I always have. When I attached the battery back though there was a problem, I think some kind of short, with my temperature control panel. It's hard to explain but I'll give it a try. The panel will not turn off, when I turn it off it resets itself but then immediately turns back on. No amount of fiddling with fuses or the battery will make it turn off. Also the fan stays in this sort of limbo. The fan on the display has 4 little blades corresponding the 4 different levels of the blower. These are constantly going from least to most pretty quickly so that the little blades on the display look like they are moving in a circle while the blower still remains at a constant rate. I believe there to be some kind of short, but I guess I'm asking if this has happened to anyone else? Also if anyone knows anything about this whether I will have to replace the little module or if there can be some other way of resolving this or finding the short and fixing it. I've pulled some fuses to check on things, but the ones I checked weren't blown. I've also disconnected my audio system, but it did not make any difference either. Any help would be great. This is my first time on here so thank you ahead of time.
John [email protected]
