98 Q45 transmission
sm5coat
Car: 1998 Q45
2001 I30
My 98 Q45 transmission is slow shifting into drive the 1st time each day. It seems to shift to reverse quickly but not drive. It works fine the rest of the day and while driving. I have changed the fluid but that didn't help. I have done some research regarding the shift solenoids but the discussions seem to refer to the 1-2 & 2-3 shift not p-d. Has anyone had experience with this issue. Thanks
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
How many miles?
sm5coat
Car: 1998 Q45
2001 I30
182,000 mi
BadQ45t
Wow, you could be on the way out. My advice is to find a good transmission shop and have them evaluate it. A rebuild is going to cost a hell of a lot so maybe your going to get lucky and it is something around it.
FInd a trusted shop NOT Amco and get it professionally evaluated ASAP........it might not be worthwhile to fix but will
qship96
Car: 1996 Infiniti Q45
Had a coworker with a older Buick Lesabre with exact same symptoms- car would not go when placed in "drive" only when cold-he would let car warmup 5-10 minutes then all was fine for rest of day, unless it was winter-then if car sat for hours, same thing would happen......he drove it for 2-3 years like that!!!! Finally donated it and bought another car
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
qship96 wrote:Had a coworker with a older Buick Lesabre with exact same symptoms- car would not go when placed in "drive" only when cold-he would let car warmup 5-10 minutes then all was fine for rest of day, unless it was winter-then if car sat for hours, same thing would happen......he drove it for 2-3 years like that!!!! Finally donated it and bought another car
Shame on you for comparing our beloved Q to a lowly Buick. :nono: I'm sure the Buick's problem was due to shoddy QA at the manufacturer, whereas the Q's problem is surely lack of maintenance by a PO.
Try changing out the factory filter, as it sounds like a low line pressure symptom to me...
Lokim
