Ok, now that our weather in Illinois is starting to warm up, I have been using my sunroof on the few days lately that have been above 50 degrees. On a day that it got to 62 degrees, I went to open the sunroof and it got stuck (stopped) opening and even closing. I had to help it along. I tried to spray some PB Blaster on the tracks and that helped a little, but it still got stuck a few more times. Is the motor starting to die or do I need to do something with the track and/or rubber seal around the sunroof panel?
Anyone else had probelms with their motor starting to go and needing a replacement unit? I don't want my sunroon to suddenly stop working with the panel wide or partially open over the summer.
Any info would be great. I found several used motors online, but not sure if I want to try a used motor or spend the $$ on a new or refurbished one.
Thanks,
Ted
