Just in case.....
I was having what looked like "flooding" issues with my car, and suspected that there was some fuel leaking throught the injectors/ o-rings. Because of this I did a complete "leakdown" test. In the process I made some mistakes and had some "false" results. At one point I thought that I had confirmed my theory about the leaking injectos...but I was wrong...
Getting the fuel lines completely blocked/closed just by clamping them, proved to be quite challenging. It wasn't until I disconnected the return line and fully blocked it, and used a heavy-duty clamp on the feed line that I was able to get a good test....and the result: no leaks.
My result confirmed Q45 Tech's feedback: injectors typically do not leak....
Here is the link to the posting so that you can get some more info and see some pictures on how I did the test...
zerothread?id=298955
I just want to make sure you have good test results before you take the next steps...
Note: At one point I was so convinced there was a leak that I ordered three sets of o-rings.....
Modified by Mint Q45A at 8:40 PM 12/19/2007
