QCumber »
https://forums.nicoclub.com/qcumber-u82461.html
Thu Dec 06, 2007 1:40 pm
I have abbandonned the transmission post as I have pretty much eliminated that as a problem.
Here are the two symptoms that are still bugging the s**t out of me:
1) hesitation and bucking (only happens between 40 and 60 MPH)2) after 1/2 hour of driving, I lose power. Feels almost like I am towing something or riding the brake. If I goose all the way up it will run to 4k rpm and move a little but other than that it just put puts around like a golf cart that;s running out of battery.
#2 above almost inevitably gets triggered by shutting the car off for a few minutes and cranking it back up.
Here is what I have done so far:
1) Cleaned transmission pan, new filter and gasket - no problem there2) all injectors ticking properly3) plugs have even burn, cylinders look good and hold even pressure all around4) EGR moves up and down when you throttle up and down (I even took it out of the loop alltogether with no result)5) tried two different used MAF sensors off a couple of Maximas (same exact part) we have in the shop - same result5) Tested head temp sensor (I know someone on here said the Q didn't have one, according to Alldata it does exist and I was able to test it within operating parameters.6) Tested TPS and secondary TPS both operating within proper resistance7) replaced fuel filter (looked like black sand coming out)8) Replaced IAC assy - still no change9) ran out of hair to pull
I am really frustrate with this. I have been working on cars for a long while and have resuscitated many project cars when it shouldn't have been possible but I feel like a complete idiot at the shop day after day farting around with the same car...
I am contemplating swapping out the fuel pump but I have put a lot of money rehabing this car (body wise) just not sure how much more I want to put in it.
Thanks again for your time thinking about this.
