BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Thu Oct 09, 2008 7:18 am
Drop in some additional information like how many miles on the car, what services you know where performed.
First thing as mentioned, Lee Myles ain't the place to take this car. Find someone that knows these cars and if you cannot find a history of solid fluid changes you need to dump all fluids immeidately. I'd get a place that do a transmission flush, that means 15 quarts of transmission fluid out and 15 quarts in. I have a 97' and run redline synth. You also should flush the radiator, brakes and power steering. If you are over 60k and cannot see that the spark plugs were replaced I'd do that while i'm in there, along with air filter, fuel filter, interior air filter etc.
You need to drop 1k minimum into this car ASAP unless you have a written history that shows someone did these. I have had my Q for 8 years and went from 40k from the original owner to 90 without one repair, but i have flushed everything twice going on three times, which is way more than you need, but way better than replacing the big parts they lubicate.
also while your at it switch over to at minimum Mobile 1 syth or Redline or Amsoil if you want to do it A1.
Post more and we'll guide you, but these cars are reliable if regularly serviced only.
