the intake sensor is located on the downstream side of the evaporator..
Its most likely short circuited because resistance goes down as temperature goes up..
http://www.nicoclub.com/FSM/Q45/1998_Q4 ... Q45/ha.pdf
go to page HA-71... That shows about everything. it does not look like its going to be much fun to replace, but its possible it may not be too bad. it seems that I recall on the G50s that the cooling unit is a 2 piece setup, so you might be able to only remove the bottom part so you dont need to remove the evaporator..
Personally, for a temporary fix so your AC works fairly normal I would get a couple small resistors from radio shack.. I think a 2 k-ohm resistor would do it.. Just unplug the sensor and put the resistor in the 2 terminals..
