BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Fri Feb 23, 2007 10:59 am
With that amount of mileage on the car for sure you shocks/struts are history, your on mush and you don't even know it. Also the control arms have rubber bushings on the ends and they are worn out usually by 75k, I would replace all shocks and struts, get the end links on the control arms checked, chances are they need replacing, than get the aligment done.
The Struts and shocks replacement you have little choice, either you go OEM or you'll have to find Onetongrage on this board to get you some very expensive but very nice KYB SR Specials from Japan. There are zero choices for aftermarket stuff, not even crappy Monroe makes a replacement for our years.
I would say your chasing around a meaningless thing until you address these issues, there are lots of other rubber parts along the way you might want to replace on the way. If you go OEM everythinginfiniti is Scotsdale Infinit and mail order they sell cheaper than anyplace, plus over state boarders no sales tax. They will set you back close to $500 but will be well worth it. The KYB SR Specials are closer to $700, depends on how performance minded you are. You might also order some strut tower mounts that can be changed out when the mechanic is doing the struts up front and have them check to make sure everything is straight and not been in an accident.
