tfvesquire »
https://forums.nicoclub.com/tfvesquire-u83121.html
Tue Feb 05, 2008 8:48 am
** UPDATE ***
Ok, I found out the problem. I also posted in the IOM section as well. It turns out that the drivers rear door window switch also controls the door lock signal. The door was unlocking, but not locking with the master switch and/or keyless. So, the system would not completely arm itself bc it did not receive the message that all four doors were closed and locked. That seems to be why my lights would not flash.
I replaced that switch and now all the doors lock and unlock and the lights at least flashh two times for armed. They don't flash the one time on disarming, but I can live with it the way it is.
I did discover that in the process of removing that dreaded window tint on the rear window, I ended up scraping off some of the keyless remote antennae, which is painted onto the window. So, in addition to repairing the defroster lines that I severed, I will have to also repair the keyless antennae so I can use the keyless more than a foot away form the car. Right now, I have to stand right next to the car and point the remote at the rear window to activate my alarm system. Really a PITA, but it can and will be fixed shortly.
Hope this helps one or more of you out there who know about as much as I did about the electrical system in our cars (nada!!). That is the purpose of this forum --- so far, most members have been a great help.
I will post more as I complete one project at a time.
Later,
Ted
