DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Jul 01, 2003 11:36 am
I'll add, in case it isn't obvious, that low refrigerant might not be the problem. Something else might actually be malfunctioning, and the refrigerant level may already be fine. R-134a systems can only be properly filled by weight, and overfilling will cause a drop in performance. Adding a little R-134a and hoping for a fix is probably the cheapest route, kind of like throwing parts at a problem if the parts are cheap and the labor negligible. But it is by no means a guarantee and you need to be aware of this, since there are potential hazards with overfilling a high-pressure system aside from the cooling performance. A cheap gauge-set can be bought and used to aid in diagnosis, and to get you "in the range" of properly filled. R-12 systems have a sight-glass on the receiver-drier to aid in system diagnosis.
