Q45tech wrote:What does the coil [modern coil on plug] have to do with plug life, could it be that they didn't want the coil disturbed until 100k, when the legal life of the engine is over?
True, but it may be a reasonable inference that the construction quality of the coil pack for the VH41DE was not compromised vís-a vís the VH45DE coil pack as the VH41DE coil pack obstensibly needed to last the extended service interval without failure.
Then again, maybe not, since it would be beyond the coverage of even most extended warranties if it failed at the end of the OEM recommended service interval.
In any case, haven't seen too many posts on their failures, and I think the few were on the VH45DE at 100K+ miles. Usually it is improper removal technique that leads to damage and subsequent failure.
