duck3986 wrote:Hi,
I have a '98Q that I've worked on a fair amount but I'm stumped. I just today noticed green drops of antifreeze in the snow running up my driveway. So I know it's from my Q and it's leaking as the car is running.
Why I'm stumped is that my coolant is red. I also checked my coolant level in my overflow tank and at the top hose cap and it's full.
Is there a transmission fluid cooler on my Q? Does the transmission cooler have different coolant?
If not, is there anything else on my Q that could have antifreeze?
Thanks,Don
Maybe the Grinch got shot in your driveway and escaped while wounded?
Yes there is a transmission fluid cooler incorporated into your radiator unless an external transmission cooler was installed. Either way, it uses the same coolant. The coolant is circulated by the water pump...it runs through radiator, through pockets in the engine and through your heater line extending into the passenger compartment....it's all the same coolant.
Seriously though, if your'e worried that it's your car. Warm it up and get under it to see if you can detect any drips. Mechanics also have a pressure pump that they attach to your radiator then pressurize to detect leakage. Just stop by any shop and have them diagnose it that way.... should be pretty cheap.
Maybe someone with a leaky rad turned around using your driveway?
...Drew..
