renoron »
https://forums.nicoclub.com/renoron-u57684.html
Wed Feb 13, 2008 3:26 pm
Weird situation going on with power steering. Started out as a "groaning" noise upon start, but did not get louder when turning. Checked ps fluid level - all OK. Checked belts - all OK. Since I'm 100 miles from nearest Infinity dealer (Sacramento), scheduled a next-day visit to local shop. On the way to the shop, the power steering "failed" as if there was no assist, but the groaning stopped.
The local guys tried everything they can think of to isolate the problem, including called Infinity for guidance. The consensus is there is a air bubble or some other kind of blockage in the system, but there are no noticeable leaks from which air and/or fluid are escaping.
Another anomaly is that the ps reservoir has fluid in the top half, but nothing in the bottom half! And when I turned the car off, ps fluid boiled over (my term) from the blew ps fluid all over the frame from the reservoir cap. As I understand it, this a gravity fed system, so I am befuddled as to how I could have fluid in the top, but not the bottom. Hence the air bubble theory.
Hoses have been checked, the system bled and nothing seems to isolate the problem/blockage. Infinity says in 90% of the time the ps pump is the culprit. I'm willing to do what needs to be done, but I don't just want to start throwing parts at it.
Any suggestions/tips would be appreciated.
Thanks
Ron in Reno
