Nuf Said »
https://forums.nicoclub.com/nuf-said-u154903.html
Thu Feb 25, 2010 6:59 am
I have a 97 Pathfinder and live in Boulder, Colorado. Have had this issue several times over the years. Always at higher elevations. Always in the winter. Here's what the local Nissan and AAA have recommended, and it has worked for me:
(1) If you can remember before starting the car after a day of skiing, hold the pedal to the floor for a second then start the car. Slowly release the pedal as the car starts up. If you forget to do this after your vehicle has been sitting for some time at 7,500+ elevation in the winter, this is when you're gonna get yourself in trouble.
(2) If the first step doesn't work, find the Fuel Pump fuse and pull it out. In my car, this fuse is located behind the change drawer to the left of the steering wheel. FYI: You do have to physically remove your change tray to access the fuses. Find the Fuel Pump fuse. Pull it. Then try step (1) again. This has worked for me three out of three times now. Once the car has started, put the fuse and change tray back in.
Best of luck!
