jmcondra »
https://forums.nicoclub.com/jmcondra-u23175.html
Sat Dec 11, 2004 11:21 am
UPDATE:
I cut the wire on pin 5 of the Transmission Control Unit and connected in a 2 position push button switch. In one position, I give 12 volts to the Tourqe Converter Clutch solenoid. In the other position, the TCU can control it.
I test drove it for 30 minutes. When I push the switch to lock up the TCC, it stays locked up, even at high speeds. In the other position, it won't stay locked up at high speeds.
So, I think my TCC solenoid is good.
Any ideas?
Thanks
