I replaced my bank 1 upstream O2 sensor today, hell yeah I can do that! Hahaha... Well maybe its not even the problem. What does this mean? rarely breaks? and this is a quote off the webpage that sells the part.
On some vehicles, the driveshaft is made up of two pieces and is held in the middle by a Nissan Pathfinder Driveshaft Support at the middle of the vehicle. When your bearing is dysfunctional, the Nissan Pathfinder Driveshaft Support will need to be removed and replaced. Your Nissan Pathfinder Driveshaft Support will rarely break, however the device should be removed from your vehicle if you rebuild the driveshaft. The car's Nissan Pathfinder Driveshaft Support helps support the backside section of a driveshaft just before it attaches to the vehicle's rear differential.
Edit: So are they talking about the support being, what the bearing sits in?
