98 pathfinder p0720
cummins_nut
Car: 98 Pathfinder
Is this sensor on a 98 pathfinder 4x4 Automatic? And where can i get one. I cant find one from oriely's so I imagine it is a dealer item only! I am throwing the p0720 code and have replaced the output shaft speed sensor and still have the same code. The wiring was checked by an automotive electric tech and found nothing. I am getting a lot of transmission fluid leaking. This made me think of the turbine speed sensor. I get o2 sensor codes intermitently and shift slippage so I imagine the trans fluid is causing the o2 sensor to be faulty when the fluid runs to it and the shift slippage is from the faulty turbine speed sensor. Any help on this would be great. Thank you
