98 Pathfinder no AC
llamuh
Car: 98 Pathfinder
I'm new here but I know with most forums the first response is, "read the stickies!" or "have you tried the Search feature?" so I've done both of those first.
I have a 1998 Pathfinder with AC issues. A year or two ago, the compressor was barely turning so I got the whole thing replaced. The AC worked great for the first year or so and then I basically stopped driving the vehicle for a few months as it is just a secondary vehicle. This past spring I started driving it more often and the AC blew nice and cold. The vehicle sat for another month or so and when I went to drive it again, I found that the AC doesn't blow cold at all. The blower is working fine and blows at variable strength/speed depending on what the dial is set on, as it should.
The compressor appears to be turning with no issue and I do not hear any odd noises. The little light on the AC button comes on, however I noticed something odd. When I turn the AC on and off via the AC button (with the fan turned On to whatever setting) I can't "tell" that the AC is on. What I mean is that in most car's I've been in, including the Pathfinder, there is a different sound from the motor and the idle RPM changes when the AC is turned on and off, I assume from the load on the motor. I can also normally feel the difference if I turn it on/off while accelerating. The fact that this isn't happening makes me think the issue is electrical rather than all of the refrigerant suddenly leaking out.
I changed out the fuse (one under the hood on driver's side) with a known working fuse but it had no effect. I saw a connector with two wires going into it that seems to plug into the top of the compressor, so I took it off, stuck some small electrical wire into each hole in the clip (probes wont fit in the connector holes), and attempted to test it with my multimeter. I could not get a reading off of it whether the AC button was on or off. I'm assuming that I should read some sort of voltage from it if it was working correctly..
Any ideas on something else I could check? I know summer is almost over but it is still pretty hot here and I'd like to have it working. Any input would be much appreciated.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Try swapping the A/C relay with another one of the same color.
llamuh
Car: 98 Pathfinder
Is the relay the part that I called a fuse? (large blocks in a box under the hood on the driver's side)
If so, it is blue and I swapped it with another blue one and it had no effect. It would make sense that this was indeed a relay rather than a fuse. Maybe I should be looking for a fuse?
Towncivilian
Yes, the blue item you swapped out is a relay.
Do you have the automatic climate control, or manual knob-type controls?
llamuh
Car: 98 Pathfinder
Manual knobs with a rectangular button to turn the AC portion on and off.
it looks just like this:
Towncivilian
Can you try following the diagnosis procedure described on page HA-151 of the factory service manual as best as you can?
