98 Pathfinder E-brake light staying on
swag
Car: 1998 Pathfinder
Hello,
I have a 98 Pathfinder and over the last two weeks the e brake light has started randomly staying on.
Any suggestions on what I need to check to make this stop?
Thanks,Swag
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
add some dot3 brake fluid. You may be low.
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
The light on the dash isn't only for the e-brake, it's also a warning lamp. The fluid level could be low. It could also be an electrical problem with the switch on the e-brake that controls it, but I'd begin by checking brake fluid level.
edit: whoa I was too slow
swag
That did it. I was barely above the min line but filled it up to the max line and it went off.
Thank you!
KoukiS14
Excellent news!!I had a vehicle that had the latter problem, but I never fixed it.
