98 Nissan Pathfinder 4x4 3.3L will not start
MoNo
Wonderful story. . . My wife calls me saying she just got some gas and got on the highway and and the car felt like she didn't put enough gas in . . .so she stopped again and to be sure it wasn't bad gas or something she got a treatment and dumped it in too.. .
She went to go start the car and it dies right off. .. I get there and try to start it. . .yea it dies out unless i keep my foot on the gas. As the RPMs rise they aren't steady at all they're jumping between 2-4,3-5,5-7, as it rides around the meter. The car stayed on this way long enough for me to back it up and drive it forward about 2 blocks. I started out going slow only 10 miles an hour. When i switched gears the cars almost dieing out if i dont keep the gas in. . Finally about a block down the road 1/4 mle or so going about 20 miles an hour.....it drops to 10 then 5 then nada. .. . hasn't come back since. I've since replaced the battery, distributor cap, the rotor, the fuel pump and filter and am unsure where to go next. Any ideas? I dont have a code reader so I have no idea about that but there's no check light on currently
MaximA32
Check your MAF and see if it's clogged.
MoNo
looked fine replaced it 3 months ago
The engine is trying to turn over. . .the starter is going. I've checked the fuses..
still nothing. The engine cranks and turns over but no kick
Twilight sentra tuner
Car: 00' Sentra Gxe
is ur MAF on backwards?
MoNo
It ended up being the ignition coil and camshaft position sensor
