vitalik »
https://forums.nicoclub.com/vitalik-u78202.html
Wed Oct 10, 2007 5:49 pm
Hi! Thanks for reply...It has 230K, oil changed every 5K, use Castrol only...I own it for about a year, have all service records from the previous owner, so gunk is least likely...I did suspect timing chain tensioners, there are two of them, lower was checked and serviced with new (nissan modification) gasket, upper unknown, since it is a lot of work to get to and pretty expensive...Will try an oil filter maybe with flowback valve, don't know what else!? Any idea?
