98 nissan 200sx fwd sr20det swap help
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
custom1SER
Car: 1998 nissan 200sx ser
hey everyonei have a 1998 nissan 200sx ser and i want to swap to the det i was just wondering what would i need parts wise if anything special has to be done any complications that i would run into that are common with the swap and just curious if the wiring harness would plug and play i mean i have a sr20de in it now just curious if its the same
thanks
nametakennow
Car: '06 MINI Cooper S
Plug and play. Just figure out what ECU setup you want to use, get a high-flow fuel pump, and go for it.
custom1SER
thank you i wanted to use a gtir but that comes with a awd trans i was told i can swap my trans on and it would bolt up the only thing is i was told that the trans cant hold much hp up to 300 then it is junk and i plan on running a fmic and eventually making above 300 what should i do about the trans
oldschool1921
Car: 94 Nissan Sentra GTiR
I have done the sentra GTiR swap and it took a while, but it was just due to programing. I ended up running a full stand alone FMU. It runs great though at 298WHP with the stock turbo and more fuel
custom1SER
can i run the stock trans on it? and what do i got to do to make it work i was told that i need to do some mods to the wiring harness and everything?
nametakennow
Your trans will work fine. I want to say that you have to use the GTi-R flywheel, but do some searching to confirm that.
Yes, there is also some wiring to be done. Pretty sure it's just the injectors. Again, a search will turn up the answer. I know it's been outlined a few times.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Use your stock transmission and any aftermarket upgraded clutch for the 200sx se-r. The GTiR swap is too much of a headache. It is easier to swap in a U12/U13 or W10/W11 and it is almost a direct swap utilizing your wiring harness. I recommend the w10(avenir) which can be purchased from tigerjapanese.com for $900. It has the silver valve cover and doesn't come with an intercooler. If you need more power, than find you a GTiR T28/manifold for sale and bolt it on. I made 280whp/280ft-lbs on my bluebird motor and GTiR T28 setup. I have now gone to the disco potato. You will need some type of engine management and I recommend a calum ecu.
200sx GTi-R
Car: 98 nissan 200sx se-r
im brand new here but i am in the middle of a 200sx se-r gti-r swap my self and what i have come up with is that you need the resistors wired inline for the injectors, i myself am running a b13 jwt ecu, the stock fwd trans will work just fine, but the bolts that bolt the flywheel to the gti-r motor are different then the usdm sr20de bolts so......if anyone can help me out with that id appreciate that.
im not to good with this forum yet so plz call with any help (920)251-4588
Jake
RED_DET
Vendor
2011 Infiniti G37x
You can't use a b13 ecu as it is OBD I and the 200sx is OBD II. I answered you problem in the other thread. Use your flywheel bolts, your transmission and an upgraded clutch for the 200sx. Nothing from the GTiR transmission will you need, its useless.
gtir227hp
Car: 1996 Nissan 200sx se
the motor came with everything except the transmission cuz its awd. It also came with the clutch and flywheel and i was wondering if i could use gtir clutch/flywheel with ser transmission? I havent got ser 2.0 transmission yet and today i got 1991 sentra motor mounts and they wont fit the gtir motor and the mounts that are currently on my stock 1996 ga16 motor wont work either. I dont know which mounts will work?? I was also wonderin if the ecu that came with gtir will work and if I will need 2.0 axles or if i can use the same ones? i would really appreciate any help i need to get this swap done asap
gtir227hp
I heard that I might need to have custom made motor mounts. ugghh crap! hope not unless anyone knows which ones i need?
nametakennow
You need 95-98 SE-R motor mounts.
Search about the flywheel and clutch. I know it's been discussed and I want to say there's some sort of minor mix and match involved with the GTi-R, but a search will confirm that.
brandipie
Car: 1995 Nissan 200sx
Hi I have a 1995 Nissan 200sx that I'm doing a motor swap in I bought an sr20DET motor what motor mounts do I use and someone told me that I would need brackets also is this true thanks and please help my e-mail is [email protected] and thanks once again
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
