98 maxima vibrating while stopped at lights at night
Jla117
Car: 98 Nissan maxima
Is my battery dying? My car vibrates with the headlights on while staying stopped at a light. I put on the fog lamps and then it vibrates a little more. In the day time you could barely feel any vibration. My battery in load meter tested at 11 volts under a load with car off. Without load it was 12.9 volts. That vibration just makes the car seem crappy. I want a perfect idle.
PapaSmurf2k3
Site Admin
Does the idle dip lower too? Maybe your alternator is starting to go out, or your idle control valve is getting clogged up.
Jla117
I have a brand new alternator there
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Check belt tension and belt tensioner
PapaSmurf2k3
Site Admin
And the idle control valve... might be worth giving the car the seafoam treatment.
Johndunbar
According to me show your car to the mechanic or to the car servicing company. They will suggest you the exact problem and also the solution to the problem. They will also help you to repair it accordingly.
