Hi, Thanks for your response Maxhopper.
I have replaced:Fuel Pump, Fuel Filter, Starter (because original burned out trying to start the engine), spark plugs, Cam position sensor, Temperature Sensor, Ignition switch.
Carryover from original motor: all sensors, spark plug coilpacks, wiring harness, Intake manifold, Mass Airflow Sensor, Throttle assembly.
Original motor was tired, but running smoothly. That was why the choice was made to carry over all these items.
Original transmission was slipping really badly too.
First shop replaced the knock sensor, second shop replaced the temperature sensor, third shop replaced the ignition switch.
The crank sensor was mentioned at the third shop, but the scan turned up nothing. Shop also thinks that it might be a bad ECU, but they are now grasping at straws, just like the first two shops.
Would a bad crank sensor turn up on a scan? Is there a relay or fuse that could be doing this? Bad ECU?
I have owned this car since November, it has left me stranded three times, for three different items. I have driven three days in the three months.
Looking back now, the previous owner owned it for 8 months before I bought it. I should of seen this coming.
Heeter
