98 Maxima GLE - Front Passenger door will not open.
MAXIMUS Nismo
Car: 95 240sx SE
Hi all, I haven't posted in a while but I need your help with this issue.
About 2 months ago, the front passenger door refused to open. When I open the auto locks using the driver door switch, the locks open then close immediately. This happens about 3 times and on the 4th try, the front passenger door makes a ticking noise and then the locks will remain open, except for the frnt pass door. The Video below will show what I mean.
[youtube]http://www.youtube.com/watch?v=kqhsCIF3aqM[/youtube]
Things I've done. - Research pointed me to possible corrosion/ faulty solders on the circuit board of the Body Control Module (BCM). I found it behind the radio and removed it but the circuit board looked fine.
I'm currently at a loss as to what the issue is and I'm thinking of getting a sawsall and hacking the door interior apart to see what I can see.
Help Please.
tigersharkdude
Car: 1999 Nissan Maxima
Try unlocking it from the outside using the key.
On that door...first use key to lock doors. Once locked use the key to unlock all doors....This worked for me
MAXIMUS Nismo
Car: 95 240sx SE
The key doesn't unlock the door, I've tried. But I haven't tried locking it with the key then unlocking it ad u suggest. Will try that next.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Problem may be with pax control unit or mechanical linkage. Better remove the door panel and inspect.
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Loystock is right on. I suspect linkage issue. I had this problem on my 2000 which was an easy fix.
