98 Maxima alloy wheels - will they fit?
old sparks
Car: Rogue
I'm waiting on delivery of a base-model AWD rogue with steel wheels, and I'm hoping to take advantage of a free snow tire offer and started looking for a used set of alloy wheels to mount the all-season tires.
I've spotted a set of 16" Nissan alloys from a 98 Maxima that are in good shape, but the gentleman selling the wheels said that a potential buyer who owns a Quest tried them and the wheels contacted the brake calipers.
The seller advised that the wheels are marked:
SA-6
MB23
16 X 61/2 JJ 5 97
45
8
OL 710
55
I assume that these are 16" by 6.5" wide with a 45mm offset. Any guess as to whether these will fit my soon-to-be delivered Rogue? I think the Rogue uses a 40mm offset, if I'm not mistaken.
TIA
TRANCEBOY
Car: Rogue SL
I JUST PUT A SET OF 20'S ON AND THEY WHERE 40 OFFSET. THEY FIT COMPLETELY FLUSHED WITHOUT ANY PROBLEM. I THING THE 45 OFFSET WOULD BE WAY OUT OR WAY IN . I WOULD SAY HOLD OF AND FIND SOMETHING WITH THE CORRECT OFFSET
philipa_240sx
old sparks wrote:I assume that these are 16" by 6.5" wide with a 45mm offset. Any guess as to whether these will fit my soon-to-be delivered Rogue?
Hard to say. Wheel designs vary greatly so simply looking at sizes does not guarantee a proper fit. I don't know of anyone who has tried these particular Maxima wheels so I don't know for sure.
I use 16x6.5 +45mm offset '02-06 Altima steel wheels (with winter tires) on my Rogue. They fit just fine. IMHO see if you find a similar set of wheels. There are tons of used Altima's out there so it should be easy.
Correct, the stock Rogue offset is 40mm.
old sparks
Car: Rogue
philipa_240sx wrote:I use 16x6.5 +45mm offset '02-06 Altima steel wheels (with winter tires) on my Rogue. They fit just fine. IMHO see if you find a similar set of wheels. There are tons of used Altima's out there so it should be easy.
Thanks! There doesn't seem to be any shortage of used alloy OEM wheels around here, so I think I'll wait until I take delivery before I buy some rims.
Jostudly
Car: 2009 Nissan Rogue
What is the factory size 16"alloy rim for the Rogue? Also where is the best place to get a good deal on 16's?
Return to “Rogue Forum”
