Anyway to pinpoint exact problem myself ? I just had knock sensor replaced and thought I was done.
Anyways according to this it could be one of many candidates.
EVAP canister is a canister that looks like a bucket and it's located on one side of the gas tank when you look at your undercarriage. It sits on the opposite side of the muffler and on the same side as the gas cap. P0440 may be caused by defective gas cap but when you get both P0440 and P1448 then the cause is one of the following: EVAP canister vent control valve, EVAP control system pressure sensor and circuit, Blocked rubber tube to EVAP canister vent control valve, Water separator, EVAP canister is saturated with water, Vacuum cut valve.
So, as you can see, you need to take the car to a shop and inspect the EVAP system, you'll be lucky if it's just some valve or hose, the worst case is the canister itself, which costs close to $400 from the dealer. I can't list the procedure to verify the exact defective component here, it's too long.
Anybody got the procedure that this guy is talking about.
Any service bulletin on this combo?
