98 max 3.0 engine
Discuss topics related to the VQ series engine.
lazarus
How do you adjust the altenator belt? I can not get it to pivot freely.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
whiel I am not familiar with the maxima al the vg's i've seen use a tensioner and the alternator does not pivot, you have to locate the idler pulley, and loosen the nut in the middle of it, then locate the tensionioner bolt going perpendicualr to the pulley, turn it counterclockwise to loosen, hope this helps
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
98 Maxima has a VQ, not a VG.
evildky
06 Nissan 350Z GT
I guess he posted in the wrong section? same tensioners?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The belt idler pulley has a fine screw adjustment. It has two parts: one screws tight to lock the adjuster itself, and the other screws or unscrews to adjust the belt tension (see the picture below).
http://is.rely.net/3-4-5798-l-...w.jpg
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
