98 ka24de swap to 91 ka24de differences?
fcoyne00
hey guys, anyone know all the differences between 98 ka24de and 91 ka24de? im looking to put a 98 motor in my 91, and im wondering what the difference is betwqeent the engines such as cylinder heads, valve train, intake manifolds, exhaust manifolds,etc. any info will help thanks, frank
SeVa-S13
Car: '05 GTO 6spd
I know atleast the S13 cams are "hotter". Swap the cams for a ghetto way to wake up your top end a bit. ;)
SHIFT_Lock
Car: kouki s14
obdII.....the s14 motor uses different sensors and a diff btu valve and egr ...so the best thing to do is change over the egr btu the intake the exhaust manifold distributer and coil. if you use the s14 transmission change the speed sensor also.
basicly just use the head and block. and maybe transmission. evrything wil just plug rite in then.
quiksilvia
Car: 95 s14 se
scroll button scroll button1...2...1...2...and if you swing by my crib then i can scroll with you
