loystock »
https://forums.nicoclub.com/loystock-u10145.html
Tue Nov 10, 2009 11:23 pm
Car seems like in 'limp mode (limited RPM with injector firing simultaneously). Please make sure that all electrical connectors are reconnected after you replaced the thermostat and radiator.
It's possible that you have corroded MAF (Mass Air Flow) sensor connector. The MAF sensor is mounted in the air intake duct close to the air filter box. Use contact cleaner on the connector and then apply dielectric grease on the pins to prevent corrosion. It would be better to clean the MAF sensing element, too. You can remove the entire assembly that houses the MAF sensor. Use a zero-residue contact cleaner (or MAF cleaner from AutoZone) to clean the sensing element. DO NOT TOUCH THE SENSING ELEMENT.
