98 I30T is starting way rough
I30T
Car: 1998 INFINITI I30T
I've searched, and maybe I'm just oblivious, but I'd just like to cover my bases and make sure I have all the info I can get.
In the past, I've had starter issues where I had to give it some gas to start it. As long as I tapped the accelerator, it would wake up fine.
Well, the car had been hanging out for about a week with no activity, and when I went to start it yesterday it sounded like a cat being thrown underwater. Instead of "vrrent-rrent-rrent-vroooom" its more like "vzzhzhzhzeeoowwerrororr". I've started it 5 or 6 times since then, to no avail (it only feels like the car isn't going to start, i've just had to stop and take a second to let it sit, but it has eventually started every time, knock on wood!). It feels different from the problem in the past, as while it's starting up with horrible noises, if i accelerate the engine will rev, it just wont stay on sometimes. What should I check for first?
Thanks a ton.
Modified by I30T at 11:28 PM 7/8/2007
Modified by I30T at 12:39 AM 7/9/2007
I30T
Anyone? Thanks...
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
have somewhere check your charging system (alternator and battery) and maybe your starter is going out... sounds like it to me but in association with the car not staying on I suggest you check your charging system
=o I'm no pro so someone might have have some more help
